English
Problem: Geoprocessing server is unable to find the data when executing AML
An AML created in an ArcToolbox tool will not run successfully on a geoprocessing server. The server is unable to find the data.
Cause
AMLs created in ArcToolbox will not work on a geoprocessing server because the local paths contained in the AML are not converted to Universal Naming Convention (UNC) paths.
Solution or Workaround
Before submitting the AML to a geoprocessing server, use a text editor to change all local paths in the AML to UNC paths:
Local path:
Code:
d:\path\cov
UNC path:
Code:
\\machine_name\share_name\path\cov)
