PROBLEM
When specifying a label expression that involves numeric fields, the resulting label is incorrect. The Verify option, however, indicates that the expression is correct.
The field formatting is not correctly maintained in the resulting label.
Make sure you typecast the result in the label expression. For example, clng([field]) converts the value of the [field] to an integer of type long.
The following example divides two numeric fields and calculates the population per sq/km; the result is an integer value:
Code:
clng([POP_CNTRY] / [SQKM_CNTRY])
Get help from ArcGIS experts
Download the Esri Support App
