ERROR
Warning: Create output feature class failed
Error Message
When converting multiple datasets with similar names (mydata_polyline, mydata_polyline_1), the first dataset is converted, then warning message occurs and subsequent datasets are not converted.
Cause
If the names are the same, except for the numeric suffix, both outputs may be assigned the same default name. The first conversion will be successful, but the second will fail since the output name is already in use.
Solution or Workaround
Make each of the output names in the batch grid unique.
Article ID:000003106
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
