English
Error: SQL10013N the specified library "/home/db2inst1/sqllib/function/db2udp" could not be loaded.
Error Message
The ArcSDE service fails with the following error:
"SQL10013N the specified library "/home/db2inst1/sqllib/function/db2udp" could not be loaded."
Cause
This error occurs if the DB2 Application Development Tools and DB2 Application Development Client components are not selected.
The Db2udp is in the install component 'DB2 Application Development Tools(ADT)' which is in the product selection of 'DB2 Application Development Client'.
Solution or Workaround
Follow the steps below.
Verify that these components are selected when installing DB2 UDB 7.1
