English
Problem: No output is created by the Tin to Grid tool
The Tin to Grid tool closes without an error immediately after clicking OK and does not produce any output.
Cause
This tool uses the ArcInfo Workstation TINLATTICE command, which is part of the TIN extension. The tool does not check if the extension has actually been installed. If the TIN extension is not installed, the tool simply closes.
Solution or Workaround
Do one of the following:
  • Install the TIN extension.
  • Use a Geoprocessing Server that has the TIN extension installed.
Related Information
