PROBLEM
While editing your geodatabase, attempting to build an edit cache doesn't work.
A query may be failing in the database that is causing the build edit cache command to stop processing.
Use tools in the database you are using to store your geodatabase to find out what queries are failing and take appropriate action.
Get help from ArcGIS experts
Download the Esri Support App
