English
Problem: Map created in Getting Started with ArcGIS is clipped at the edges when printed
The book "Getting Started with ArcGIS", page 42, instructs you to print an 8.5 by 11 inch map. As such, your map may be clipped at the edges.
Cause
The map margins are wider than the printer's printable area.
Solution or Workaround
Click 'Scale map to fit printer paper' on the Print dialog box before printing the map.
Related Information
