ERROR
TAG THRESHOLD=3 is ignored
Error Message
When adding a TIFF image to a View, the following error occurs:
Cause
The image is true black and white and has been saved as a gray-tone or color image.
TIFF images have a THRESHOLDING tag that lets you treat a black and white image as shades of gray through dithering and halftones. If the image is true black and white, the color and grey-tone threshold settings are ignored by ArcView.
Solution or Workaround
Save the image as true black and white. This will set the THRESHOLD of the image equal to 1.
The error is a non-fatal error and occurs every time ArcView needs to
re-read the image.
Article ID:000003059
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
