PROBLEM
I created a new UIToolControl in ArcMap or ArcCatalog. When I use the tool the MouseMove event is not executed.
When the Visual Basic Editor is open the tool is in design mode and cannot be fully tested. Debugging events that occur frequently while in design mode can cause problems with the Visual Basic Editor.
Close the Visual Basic Editor to test the MouseMove event.
Get help from ArcGIS experts
Download the Esri Support App
