English
Error: Automation error Unspecified error
Error Message
When the edit operation being aborted is in an edit session started with IWorkspaceEdit.StartEditing whose WithUndoRedo parameter is false against an ArcSDE geodatabase, IWorkspaceEdit.AbortEditOperation returns the following error:
"Automation error
Unspecified error"
Cause
ArcSDE geodatabases expect the IWorkspaceEdit.StartEditing method to be set with the withUndoRedo parameter set to True.
Solution or Workaround
Start editing by calling IWorkspaceEdit.StartEditing(True).
