PROBLEM
Display Hardware Key status does not return anything
Display Hardware Key status returns an empty window or does not return anything.
Cause
Hardware key is not working.
Solution or Workaround
  1. Install the license manager on another machine using this hardware key and the corresponding license file.
  2. If Display Hardware Key status does not return the correct hardware key number on the second machine, the hardware key is not working.
    Contact ESRI Customer Service to obtain a new hardware key and new license file.
Article ID:000003033
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
