English
How To: Print with ArcPress RTL Device Dithered RGB or HP RTL RGB (Truecolor) driver
Summary
The ArcPress RTL Device Dithered RGB, known as the HP RTL RGB driver in ArcPress for ArcGIS 9.0 and 9.1, uses the true color RGB model and is recommended for those dissatisfied with the darkness of the ArcPress 7.x/8.x and ArcPress for ArcView GIS RTL drivers. It is also the only ArcPress RTL driver that is supported on the HP DesignJet 5500, 5000, 800 and 500 series printers.
The ArcPress RTL Device Dithered RGB driver supports the HP DesignJet 5500, 5000, 800, 500*, 1000 series, 2500/3500CP series, 750 and 455 series printers. It does not support the HP DesignJet 650, 250, 350 series printers nor any ENCAD printer.
The HP DesignJet 500 printer is now directly supported by way of the ArcPress PCL RGB driver, available at ArcGIS 9.0 Service Pack 2. This ArcPress driver does not require the installation of the optional HPGL2 card into the DesignJet 500.
Procedure
For ArcGIS Desktop 9.2 and newer versions, use the HP Universal Driver.
  • To print with this driver from:
    - ArcMap 9.0 and 9.1
    1. Click File > Page and Print Setup.
    2. Click the Printer drop-down list and select the appropriate HP DesignJet printer.
    3. Click OK.
    4. Click File > Print.
    5. Click the Printer Engine drop-down list and select ArcPress Printer.
    6. Click the Properties button.
    7. Click the Driver drop-down list and select HP RTL RGB (Truecolor).
    8. Click OK on the ArcPress properties dialog box.
    9. Click OK on the print dialog box to print.
    [O-Image] ArcMap 9.x ArcPress RTL RGB props
    - ArcMap 8.x
    1. Click File > Page Setup.
    2. Click the Printer name drop-down list and select the appropriate HP DesignJet Printer.
    3. Click the Printer Engine drop-down list and select ArcPress Printer.
    4. Click OK.
    5. Click File > Print.
    6. Click the ArcPress Properties button.
    7. On the Main tab of the ArcPress Properties dialog box, click the Driver drop-down list and select HP RTL Device Dithered (RGB).
    This disables the Dither drop-down list and all color options on the Color Adjustment tab.
    8. Click OK on the ArcPress Properties dialog box.
    9. Click OK on the Print dialog box to print.
    [O-Image] ArcMap 8.x ArcPress RTL DD RGB props
    - the ArcInfo Print menu
    A. Select the file to print.
    B. Select ArcPress from the Driver drop-down list.
    C. Click Print.
    D. On the Print menu, select the HP DesignJet printer from the Printer drop-down list.
    E. Select HP RTL from the Device drop-down list.
    F. Click Options.
    G. On the Color tab, select the RGB Configuration radio button.
    H. This enables the Hardware check box under Dithering. Check this box.
    This disables all the color correction, saturation and dithering options.
    I. Click OK to approve these options.
    J. Click OK on the Print menu to print.
    [O-Image] [O] ArcInfo ArcPress Windows Color Props for RTL DD RGB
    - the ArcPress command line interface (rtl_rgb)
    arcpress <input_file> -o<output_file> -drtl_rgb
    - ArcPress for ArcView GIS
    1. Click Print.
    2. On the Print menu, select the appropriate HP DesignJet printer from the Printer drop-down list.
    3. Select HP RTL from the Device drop-down list.
    4. Click Options.
    5. On the Color tab, select the RGB Configuration radio button.
    6. This enables the Hardware check box under Dithering. Check this box.
    7. Click OK to approve these options.
    8. Click OK on the Print menu to print.
    [O-Image] ArcPress for ArcView GIS Color Props for RTL DD RGB
    This driver is available in the ArcPress Version 2.0a patch for ArcView GIS.
  • There is no need to use any pre-existing ArcPress color correction or saturation options, or to select an ArcPress dithering pattern.
    These options are unavailable from the ArcPress Properties dialog box in ArcMap 8.x and the ArcPress Color tab on the Options dialog box in the ArcInfo Print menu.
  • This driver is designed to work best with the highest quality print mode setting. If the printer is not set to the highest quality mode, banding may be visible on the print.
    This driver is called HP RTL RGB (Truecolor) in ArcPress for ArcGIS 9.0 and 9.1.
Related Information
