ERROR
Line: 44 Error: 'style' is null or not an object
Error Message
When using the Search tab in ArcObjects Developer Help, the following error may occur if you click on a highlighted word of a sample help topic in the Visual Basic, Visual C++, or Delphi tabs:
Error
A Runtime Error has occurred.
Do you wish to Debug?
Line: 44
Cause
The topic needs to be refreshed before clicking the Visual C++, Delphi, or Visual Basic tabs.
Solution or Workaround
  1. Select View > 'Locate Topic in Contents.'
  2. Select the highlighted item in the Contents tab to refresh the topic.
Article ID:000003002
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
