English
How To: Change the connection properties for an existing OLE DB connection
Summary
Steps for changing the connection properties of an OLE DB connection.
Procedure
  1. Select the OLE DB connection object in the TOC window in ArcCatalog.
  2. Right-click to bring up the context menu and click Connection Properties.
    [O-Image] Changing OLE DB connection properties
  3. Modify the parameters for the connection displayed on the Data Link Properties dialog box.
    [O-Image] Modify connection parameters
