HOW TO
Perform a find or a replace on a selected set
Summary
You can use the table window to perform a find or a replace on a selected set of records.
Procedure
  1. Open the table window.
  2. Click the Select button to display just the selected records.
  3. Click Options > Find & Replace.
    The Find or Replace will only be applied to the selected set. In order to perform a Replace, you must first start an edit session.
Article ID:000002977
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
