English
FAQ: If an incorrect value is typed when editing in the table window, how can the change be undone?
Question
Answer
If the cursor is still flashing in the cell where you have made the change, you can hit the escape key to get back the original value.
If you have clicked on another record, the changes you have made are applied. In this case, click the Undo button on the standard toolbar to undo the change.
