PROBLEM
After making a change to table appearance or behavior in the Tools > Options dialog box, the settings are not applied to the tables in the map.
The settings made in this dialog box define the default behavior for the tables of new layers or standalone tables added to ArcMap. Once the data has been added to ArcMap, the current settings are applied. These settings also span ArcMap sessions and are applied to new map documents.
Get help from ArcGIS experts
Download the Esri Support App
