English
Problem: Feature classes that participate in relationships sometimes are slow to use in ArcMap
When working with feature classes that participate in relationships with other feature classes or tables in the geodatabase, navigating those relationships is sometimes slow.
Cause
The related class should always be in the map, or editing performance will decrease.
Solution or Workaround
To add your related tables to ArcMap:
  1. Click the Source tab on the table of contents.
  2. Right-click the database icon.
  3. Click Add Table.
