English
Error: Value does not match column type
Error Message
Attempting to update a column within a DBMS table with an exponential value produces:
Arc: &sv :simplecur.test = 0.001E+00
Cause
The exponential value is not being interpreted as a decimal value.
Solution or Workaround
Multiply the exponential value being inserted by 1.
Code:
Arc: &sv :simplecur.test = [calculate 0.001E+00 * 1]
