PROBLEM
In ArcMap, fixing a broken data link for a coverage layer can cause geodatabase annotation layers in the same map to lose information about their source. For a given map document, if you repair any coverage layer before repairing all annotation layers, then the annotation layers will lose their feature dataset name (Layer Properties dialog box > Source tab).
Repairing the data source of any coverage layers before first repairing all geodatabase annotation layers causes this problem.
Get help from ArcGIS experts
Download the Esri Support App
