English
Error: Installation Aborted Internal Error
Error Message
When starting the installation of ArcGIS, the installer returns the following error:
Error:
"Installation Aborted
Internal Error"
Cause
The environment variables TEMP and TMP are pointing to a directory inaccessible to the user.
Solution or Workaround
Change the values for the TEMP and TMP variables. The value should contain a directory to which the user has permission to write files.
For help with setting a system environment variable, see: How To: Edit an environment variable.
