English
FAQ: Why do picture fill symbols not display for rotated data frames?
Question
Answer
** Fixed at ArcGIS 8.2 **
Picture fill symbols will only partially display inside a rotated data frame. Use a marker fill instead. You can specify a picture as the marker symbol that will fill the polygon.
This is a known issue.
