English
Problem: Saving a Map document takes a long time
ArcMap takes a while to save a Map document.
Cause
This happens because ArcMap is also saving a thumbnail image of the Map document, which will take as long to create as a redraw in the Layout View.
Solution or Workaround
Disable the thumbnail saving option. Click File > Map Properties, and uncheck the 'Save thumbnail image with map' check box.
