English
Error: FATAL ERROR Cannot open argument file ARGRCV
Error Message
When trying to open ArcEdit or ArcPlot the following errors are returned:
"FATAL ERROR
Program failed to start or was killed
Can not delete argument file, ARGEXE"
Cause
The Novell network in use and the corresponding Novell login has a conflict with ArcInfo on startup.
Solution or Workaround
Edit the Novell login script in DOS:
Code:
SET USERID="%LOGIN_NAME"
SET USERNAME="%LOGIN_NAME"
SET HDIR="F:\\"
