Frequently asked question
Can a map template be based on another template?
Answer
A map template can be based on another template (.mxt file). This entails opening an .mxt file within ArcMap and performing a 'Save as' using a new name, or the existing name followed by the .mxt extension. If a template is associated with a map and is in .mxd file format, a new template (.mxt file) cannot be created from it.
Article ID:000002911
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
