PROBLEM
The data frame and magnifier window typically display data at different scales. When layers are set to display between specific minimum and maximum scales, the magnifier window may not show the same layers as data view.
The magnifier uses the same display subsystem as the data frame. This facilitates editing and other important tasks in the magnifier.
Get help from ArcGIS experts
Download the Esri Support App
