English
Error: Error creating annotation feature class. The table was not found.
Error Message
Converting labels to annotation returns:
Create Annotation Feature Class
Syntax error in FROM clause.
Cause
This occurs when invalid characters are specified for the annotation feature class name, such as a name that starts with a number, a name that includes parenthesis, and so forth.
Solution or Workaround
  • Specify a valid annotation feature class name. Consult your DBMS documentation for valid table names.
  • You may alternatively create a temporary feature class with the desired name in ArcCatalog, before entering the name in ArcMap.
  • Additionally, you can programmatically test a name by using the IFieldChecker.ValidateTableName ArcObjects class.
