PROBLEM
If you have Bar/Column or Stacked Chart symbology, the field alias for the normalization field does not appear in the combo box or in the Table of Contents. Only the field name appears.
This is a known issue at the 8.1 release.
Edit the label in the Table of Contents by clicking it and manually entering the field alias.
This was fixed at version 8.1.2.
Get help from ArcGIS experts
Download the Esri Support App
