Can I create a report on an OLE DB table or text file that uses the defined selection set?
Answer
The Simple Report Wizard in ArcMap supports the creation of a report based on a selection set defined on non-OID tables, such as OLE DB tables or text files. This functionality is not supported by the Crystal Report Wizard.
