English
Problem: Scale bar shifts in relation to its bounding box
After editing the layout or switching between views, the scale bar may shift position in the layout so part of the scale bar draws outside of the bounding box or selection outline.
Cause
This may be caused by having unit label or numbers below the scale bar.
Solution or Workaround
Follow the link below to the ESRI Online Support Center-Patches and Service Packs, select ArcInfo Desktop, then select the ArcGIS 8.2 Service Pack 1. Follow the instructions.
Related Information
