English
Problem: Legend columns get updated even if cancelling out of the dialog box
After checking the 'Place in new column' box, and/or editing the number of columns for a legend item, on the Items tab of ArcMap's Legend Properties dialog box, changes are still applied to the legend when clicking Cancel . The changes are apparent as soon as the legend is refreshed or moved.
Cause
Changes to the legend item column settings are applied as soon as they are made, and clicking Cancel does not discard the changes.
Solution or Workaround
To reset legend item column properties, you must manually change each property back to its previous setting.
  1. Double-click the legend to open the Legend Properties dialog box
  2. Click the Items tab.
    [O-Image] Legend Properties, Items tab
  3. Select the legend item in the Legend Items list whose column settings you previously modified.
  4. Reset the column settings by checking or unchecking the 'Place in new column' box, and/or editing the number of columns.
