PROBLEM
The ArcMap display does not fully refresh after using scroll bars
After scrolling in either data view or layout view, some parts of the ArcMap display do not draw or refresh completely.
Cause
There are many reasons why the display may not refresh completely. This is usually caused by interrupting the redraw while scrolling. If you click to scroll, and then click to scroll again while the display is still redrawing it may not refresh completely. Other causes may include network latency, low memory, conflicts with third-party tools, etc.
Solution or Workaround
Manually refresh the display by clicking on the refresh button [O-Image] ArcMap refresh button or by pressing the F5 key. If this does not help, see the web help topic, Tips on improving map display performance. See also the GeoNet blog: Troubleshooting Slow Performance in ArcGIS for Desktop
Article ID:000002774
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
