ERROR
EPS parser is unable to parse this file
Error Message
Adobe Illustrator 8 will not open ArcMap generated EPS files. The following error message is displayed:
"The EPS parser is unable to parse this file."
Cause
There is an incompatibility of Illustrator 8 with ArcMap.
Solution or Workaround
  • Option 1: Upgrade to Adobe Illustrator 9.x or later. This is available through an Adobe distributor.
  • Option 2: Import ArcMap's Portable Document Format (PDF) and Computer Graphics Metafile (CGM) formats to Illustrator 8.
Article ID:000002757
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
