PROBLEM
Some of the tables can't be previewed after the OLE DB connection is made in ArcCatalog using the OLE DB provider for ODBC sources and the Microsoft Visual FoxPro driver. The field names are listed in the preview window but no rows are visible.
If the FoxPro table includes a memo field, the data in the table will not display correctly. This is a known issue using the Microsoft OLE DB provider for ODBC sources.
Get help from ArcGIS experts
Download the Esri Support App
