ERROR
FATAL ERROR Failure during error recovery
Error Message
Rpcserver.start fails on AIX 4.3.x with the following traceback error messages:
------------------- TRACEBACK -------------------------
Module "IPC " Message 1: file "err.c " line 453
Module "Event" Message -1: file "event.c " line 2735
Module "CBlok" Message -1: file "/av31src/arcview/avenue/cblok.c" line 1552
Module "Script" Message -1: file "/av31src/arcview/avenue/script.c" line 151
Module "Script" Message -1: file "/av31src/arcview/avenue/script.c" line 324
Abort process
Cause
The nofiles option is set to -1.
Solution or Workaround
Change the value of nofiles setting to 2000.
Article ID:000002701
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
