PROBLEM
If an arrow key or the PageUp/PageDown key is pressed while a redraw of a map is in progress, the application will crash if it uses the LabelPlacer object.
Using the arrow keys to pan will cancel a redraw of the map that is in progress. This appears to cause an exception in MOPlus.DLL.
Set the CancelAction property to moCancelNone when the form with the map is loaded:
Code:
Map1.CancelAction = moCancelNone
Get help from ArcGIS experts
Download the Esri Support App
