English
How To: Create a Database Theme with fields defined by a SQL statement
Summary
You can use Avenue to create a Database Theme with the fields defined by a SQL statement. The sample script below demonstrates how to create a DBtheme with all columns, for example: Select * From table.
Procedure
Create a dbtable or SDEtable, then trap the field names and pass them to the SetSelectColumns request.
  1. Open a new script window.
    A. Activate the Project window.
    B. Click the Scripts icon.
    C. Click New.
  2. Copy the following code into the new script window.
    Code:
    '-- Get view
    aView = av.GetProject.FindDoc("View1")
    '-- Establish connection parameters
    serv = "SERVERNAME"
    inst = "INSTANCE"
    datab = ""
    user = "USERNAME"
    pass = "PASSWORD"
    '-- Make sde connection with above parameters
    anSDECon = SDEConnection.Make(serv+":"+inst, datab, user,pass)
    '-- Make a querydef object of the connection
    aQDef = SDEQueryDef.Make(anSDECon)
    '-- Use sql select statement "select *" to get all fields
    aQDef.SetSQL("Select * from TABLE.NAME")
    '-- Make a dbtable from this querydef object
    aDBtable = DBtable.Make(aQdef)
    '-- Get all fieldnames for use in the dbtheme
    theFields = aDBtable.GetFields
    '-- Make another querydef object for dbtheme
    aQdef2 = SDEQueryDef.Make(anSDECon)
    '-- Pass fieldnames list to the SetSelectColumns
    aQDef2.SetSelectColumns(theFields)
    '-- From statement
    aQDef2.SetFromTables({"TABLE.NAME"})
    '-- Make scolumn and dbtheme
    theSCol = SDESColumn.Make(anSDECon, "TABLE.NAME", "Shape")
    theDBTheme = DBTheme.Make(aQDef2, theSCol, Polygon)
    aView.AddTheme(theDbtheme)
  3. Find the words below in the code and replace them with the proper values.
    SERVERNAME - Name of the SDE server
    INSTANCE - Instance found in the Services File
    USERNAME - SDE login name
    PASSWORD - SDE password
    TABLE.NAME - Name of table to query
  4. Click the compile
    [O-Image] Script compile button
    button and then the run
    [O-Image] Run compiled script button
    button.
