English
Error: Opening an ADO/OLE DB recordset based on an unregistered geodatabase table
Error Message
An error (FDO error -2147467259) is returned when attempting to open an ADO recordset based on an unregistered table using the ESRI OLE DB provider.
Cause
The wrong locktype parameter for the recordset was used when calling the recordset::open method.
Solution or Workaround
Open the recordset with the locktype set to adLockReadOnly. Unregistered tables in a geodatabase cannot be edited using the ESRI OLE DB provider.
Related Information
