HOW TO
This article describes how to use the ArcView Projection Utility to convert data projected in UTM Zone 17 NAD83 meters to Albers Equal Area Conic HPGN. The Albers Equal Area Conic HPGN projection is one of the six projections used by the state of Florida.
If the Coordinate System field in the Step 1 dialog box shows 'Unknown', define the input projection parameters as shown below. If the content of that field is other than 'Unknown', skip the input projection parameters definition.
Make sure the 'Show Advanced Options' check box is checked.
Get help from ArcGIS experts
Download the Esri Support App
