English
Problem: ArcSDE 8.1 Java API: SeConnection.importDbtune() does not import the dbtune file
When invoking the SeConnection.importDbtune method of the ArcSDE Java application programming interface (API), the dbtune.sde file in the ArcSDE home directory does not get imported into the ArcSDE database.
Cause
The connected user must be the ArcSDE Administrator to successfully import a DBtune file.
Solution or Workaround
When connecting to the ArcSDE server using the SeConnection Class constructor, connect as the ArcSDE Administrative user.
