PROBLEM
Missing digitizer tab
Digitizer tab does not appear in the Editing Options dialog of ArcMap.
Cause
ArcMap was installed before installing the wintab driver for the digitizer.
Solution or Workaround
Register \arcexe81\bin\digitizer.dll.
1. Open a Command Prompt window: Start > Programs.
2. Type the following:
Code:
cd c:\arcexe81\bin
regsvr32 digitizer.dll
Article ID:000002684
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
