English
FAQ: Has the ArcSDE Projection Engine in the ArcSDE 8.1 Java API been ported to Java?
Question
Answer
The ArcSDE 8.1 Projection Engine, now provided through the pe81.dll library in the ArcSDE C application programming interface (API), has not yet been ported to Java. A Java solution for the Projection Engine is planned for release at ArcSDE 9.0.
