English
Error: error drawing route text
Error Message
This error occurs when running ARCPLOT command ROUTETEXT with a text interval:
Cause
One or more route sections have the same value for f-pos and t-pos in the coverage's section table.
Solution or Workaround
  1. Start Arc, then set the workspace to the route coverage's workspace folder.
  2. Start Tables.
  3. Select the sections table for the coverage.
    Code:
    Tables: SELECT streets.secnames
    674 Records Selected.
  4. Select all the records which have the same value for f-pos and t-pos.
    Code:
    Tables: RESELECT t-pos = f-pos
    2 Records Selected.
  5. Delete those records.
    Code:
    Tables: PURGE
    Do you want to purge all selected records (Y or N)? : y
    672 Records Selected.
  6. Return to ARC and run BUILD on the coverage.
    Code:
    Example:
    Arc: BUILD streets LINE
    Building lines...
    Code:
