English
How To: Mimic the functionality of the Auto-Label dialog box via Avenue's TexPositioner class
Summary
This document describes one of two ways to mimic the functionality of the Auto-Label dialog box via Avenue's TextPositioner Class. The other alternative is to use the Labeler Class, which is covered by the document in the Related Information section.
Procedure
The TextPositioner class, through its subclasses, allows you to position a text string relative to specific kinds of shapes:
PolyTextPositioner
LineTextPositioner
PointTextPositioner
Each of these can be used in two different ways. For example:
thePointTextPositioner = PointTextPositioner.Make
is the same as:
thePointTextPositioner = TextPositioner.Make(Point)
You may set the desired vertical and horizontal relationships between text and shape by using elements of the enumerations TextPositionerHAlignEnum and TextPositionerVAlignEnum. You can obtain these relationships from the settings under the Theme Properties menu option. These vertical and horizontal enumerations allow you to choose the position of the text in relation to the shape you are labeling within a script.
Vertical enumerations:
#TEXTPOSITIONER_VALIGN_ABOVE
#TEXTPOSITIONER_VALIGN_BELOW
#TEXTPOSITIONER_VALIGN_BOTTOM
#TEXTPOSITIONER_VALIGN_ON
#TEXTPOSITIONER_VALIGN_TOP
Horizontal enumerations:
#TEXTPOSITIONER_HALIGN_AFTER
#TEXTPOSITIONER_HALIGN_BEFORE
#TEXTPOSITIONER_HALIGN_CENTER
#TEXTPOSITIONER_HALIGN_LEFT
#TEXTPOSITIONER_HALIGN_RIGHT
TextPositioner objects are used by themes when being labeled. See the online help for more information on the TexPositioner class.
  • The following sample script uses the TextPositioner class to label a theme on a Single field.
    Code:
    '-- Can be used with States.shp sample data set and
    '-- works on selected features.
    theView = av.GetActiveDoc
    theDisplay = theView.GetDisplay
    theGraphicList = theView.GetGraphics
    '-- Get and labels the first active theme in the view
    theActiveThemeList=theView.GetActiveThemes
    theTheme = theActiveThemeList.Get(0)
    theFtab = theTheme.GetFtab
    theShapeField = theFtab.FindField("Shape")
    '-- Define the label field
    '-- Change the field name accordingly
    theStringField = theFtab.findfield("State_name")
    '-- This script works on a selected set of features
    theSelectedSet = theFtab.GetSelection
    for each p in theSelectedSet
    '-- Get the SHAPE to label
    theShape = theFtab.ReturnValue(theShapeField,p)
    '-- Create a String to use as the label text
    thestring = theftab.returnvalue(thestringfield, p)
    '-- Create a textPositioner using the correct shape
    '-- class of your features
    theTextPositioner = TextPositioner.Make(theShape.GetClass)
    '-- Choose vertical and horizontal alignment enumerations
    theTextPositioner.SetVAlign(#TEXTPOSITIONER_VALIGN_ABOVE)
    theTextPositioner.SetHAlign(#TEXTPOSITIONER_HALIGN_CENTER)
    '-- Create the GraphicText object using the label string
    '-- and a temporary point
    theGraphicText = GraphicText.Make(theString,Point.Make(0,0))
    '-- Set the GraphicText to a Display so it knows where to draw.
    '-- The display can be either PageDisplay (Layout) or MapDisplay (View)
    theGraphicText.SetDisplay(theDisplay)
    '-- Use the Calculate request to calculate the
    '-- position of the TextPositioner
    theTextPositioner.Calculate(theShape,theGraphicText.GetExtent,0,nil)
    theOrigin = TheTextPositioner.GetOrigin
    theAngle = theTextPositioner.GetAngle
    '-- Set the Origin and Angle of the GraphicText using
    '-- info returned from the textPositioner
    '-- in the previous two lines
    theGraphicText.SetOrigin(theOrigin)
    theGraphicText.SetAngle(theAngle)
    '-- Add the GraphicText to the graphics list
    theGraphicList.Add(theGraphicText)
    end
    theView.Invalidate
    System.RefreshWindows
  • Example 1: Using TextPositioner to label a single theme on Multiple fields by varying the vertical and horizontal alignment enumerations for each label.
    Code:
    theActiveThemeList = theView.GetActiveThemes
    '-- Return two different fields for labeling
    theStringField2 = theFtab.findfield("State_abbr")
    thestring2 = theftab.returnvalue(thestringfield2, p)
    theTextPositioner2 = TextPositioner.Make(theShape.GetClass)
    theTextPositionerType = theTextPositioner.GetClass.GetClassName
    theTextPositionerType2 = theTextPositioner2.GetClass.GetClassName
    '-- When positioning the test with the vertical and
    '-- horizontal alignments, choose two different locations
    '-- for the text so they do NOT overlap.
    theTextPositioner2.SetVAlign(#TEXTPOSITIONER_VALIGN_BELOW)
    theTextPositioner2.SetHAlign(#TEXTPOSITIONER_HALIGN_CENTER)
    theGraphicText2 = GraphicText.Make(theString2,Point.Make(0,0))
    theGraphicText2.SetDisplay(theDisplay)
    theTextPositioner2.Calculate(theShape,theGraphicText2.GetExtent,0,nil)
    theOrigin2 = TheTextPositioner2.GetOrigin
    theAngle2 = theTextPositioner2.GetAngle
    theGraphicText2.SetOrigin(theOrigin2)
    theGraphicText2.SetAngle(theAngle2)
    theGraphicList.Add(theGraphicText2)
    end
    theView.Invalidate
  • Example 2: Using TextPositioner to label a single theme on Multiple fields by concatenating all label strings into a single string and labeling at a single position.
    Code:
    '-- Return three different fields for labeling
    theStringField2 = theFtab.FindField("State_fips")
    thestringField3 = theFtab.FindField("State_abbr")
    theString2 = theFtab.ReturnValue(theStringField2, p)
    theString3 = theFtab.ReturnValue(thestringField3, p)
    '-- Construct a label string by concatenating three
    '-- label strings together with NL (newline) characters.
    theString4 = thestring+NL+theString2+NL+theString3
    msgbox.info(thestring4,"")
    '-- Choose a single position to label from
    theTextPositioner.SetVAlign(#TEXTPOSITIONER_VALIGN_ON)
    theGraphicText = GraphicText.Make(theString4,Point.Make(0,0))
    end
    theView.Invalidate
    If you are trying to label on three different fields, you may notice that even though you choose three different positions to stack on top of each other, the labels overlap slightly. You can get around this by creating one text object from three fields and then choosing one position to label.
Related Information
