English
How To: Edit metadata for feature attributes
Summary
Steps for changing metaData for feature attributes.
Procedure
  1. Select the data set in the ArcCatalog tree.
  2. Switch to the Metadata tab on the right.
  3. Click the Edit metadata button.
  4. Select Entity Attribute on the Edit Metadata window.
  5. Click the Attribute tab.
  6. Edit the attributes in your metadata.
