Frequently asked question
Why can't I update a disconnected recordset using the ESRI OLE DB provider?
Answer
Propagating changes back to a data source when a disconnected recordset is reassigned to an active ADO connection will only work if the provider supports the ADO recordset updatebatch method. The ESRI OLE DB provider does not support this functionality at present.
Article ID:000002645
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
