Frequently asked question
Why is a second ObjectID field added to a table exported from a OLE DB source to a Geodatabase?
Answer
If the OLE DB table being exported to a Geodatabase already contains an ObjectID field (data type long integer), this will be renamed to ObjectID_1 and a new ObjectID field created (ESRI data type ObjectID). This is to ensure that the new table is registered with the Geodatabase.
Article ID:000002629
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
