HOW TO
Use the ArcView Projection Utility
Last Published: April 26, 2020
Summary
ArcView 3.2 comes with a Shapefile projection Utility. You can use this utility to change the coordinate system of your shapefiles, including projections and datums. This document contains several examples demonstrating how to use the utility. You situation may be different from these listed here and require different parameters. Refer to the ArcView Help topics for more information
Procedure
Article ID:000002619
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
