English
Error: When applying a View Properties Projection to a view with CAD themes, 'Floating Point Exception' occurs
Error Message
The following error occurs when applying a View Properties Projection to a view with CAD themes:
Cause
The CAD dataset does not use the Geographic Coordinate System. In order to apply a View Properties Projection all vector themes in the view must be in the Geographic Coordinate System.
Solution or Workaround
Reference the CAD data sets to the Geographic Coordinate System.
See: How To: Transform the coordinate location of a CAD file
Related Information
