English
Problem: ArcMap closes while creating an XYEvent layer from OLE DB table
ArcMap will crash with an application error if an XYEvent layer is generated from an Access 2000 view (query) table.
Cause
This occurs when the connection to the Access file was made using the OLE DB provider for ODBC sources and an existing ODBC DSN.
Solution or Workaround
Make the connection to the Access 2000 file using the Microsoft Jet 4.0 OLE DB provider.
